Iscan HD+ Analog Output -> CRT Television
258 Views 1 Reply 2 Participants Last post by  brendank
Dear all,
I'd like to purchase the Iscan HD+ video scaling processor and I'd like to ask you to clarify one of my doubts regarding the analog output.
I'd like to use the analog output in order to send the video signal to my Crt Television (I will use DVI output with my DLP projector).
My intention is to buy a DB15 - RGB (from vga to rgb) cable in order to use the DVDO scaler as video switcher and scaler.
Will it works?
Which kind of resolution should I use (480p, 480i, 576p, 576i, 720p...)?
My TV is Bang Olufsen Beovision3 (it has input RGB connections)
thank you and kindest regards
Giampaolo Foppiani
Status
Not open for further replies.
1 - 2 of 2 Posts
i dont think you will be able to use this as the beovision 3 already has a built in scaler/deinterlacer, which is one of the reasons why you get such a good picture from it without any need for tweaking
i own a beovision 3 myself and considered hooking it up to my lumagen pro hd but it was pointless:rolleyes:
if you are looking for more specific information on bang olufsen products try
www.beoworld.co.uk click on forum/discussion board
1 - 2 of 2 Posts
Status
