Iscan HD double image problem?
324 Views 4 Replies 3 Participants Last post by  [email protected]
I have had my Iscan HD connected to my Mits RPTV via DVI for a month now and everything has been fine. I finally got my DVD player with the sdi mod back today. I connected it, and I think I may have bumped something on the front panel. I switched my tv's input to teh Iscan and I noticed a double picture. This was coming from all inputs. I disconnected the sdi dvd player to see if that was the issue, and it still have a double picture. This is on inputs that I have been using with out any problems. Anyone have any ideas? I can not even test do see if my sdi modded player is working , because I can not even get the Iscan to work with my other inputs now.
Status
Not open for further replies.
1 - 5 of 5 Posts
sounds like a timing issue.
Try resetting the output resolution to something else. Make sure your Frame rate (FRC) is set to 60Hz locked.
Steve, have you tried doing a factory reset to see if that corrects your problem? To do this, unplug the power from the back of the unit and when you plug it back in, press and hold the 'Enter/Exit' and On/Remote Standby' buttons on the front panel. When you release the buttons you should see 'DVDO' on the front panel display. If this does not correct the problem, please give me a call or drop me an email.
It was an issue with my cable box.
Can you explain further, please?
1 - 5 of 5 Posts
Status
