iScan HD with G70 pj problem - HELP!
274 Views 2 Replies 2 Participants Last post by  fvale
I connected my new HD to the G70. Great image quality!
But I've a nasty problem. Selecting a 720p output (x1280 with RGB output and H-V- sep.sync) I'm not able to fill the whole screen in width. G70 H raster control is at MAX and iScan doesn't allow to stretch image. I miss about 7 or 8 inches on each side with a 95" screen base. Similar problem with 1080i res. Everything is ok at 1024x768.
I don't have this problem with HTPC.
G70 is untouched and screen/pj distance is perfect. I don't know what to do!
May I hope in a future new firmware?
Another feature I really miss is GAMMA.
Thanks for help.
Status
Not open for further replies.
1 - 3 of 3 Posts
sounds like your timing is off. Put the unit in advanced mode and start fiddling with timing.
BE VERY CAREFUL!!! Incorrect timing has been known to blow out more than one CRT projector.
Yes, you were right, I adjusted timing and now width is ok. Thanks.
1 - 3 of 3 Posts
Status
