Originally Posted by enron29 /t/1421300/issue-converting-m2ts-to-mp4-using-handbrake#post_22241332
Hence why I'm trying to convert my m2ts files that don't really need to be HD to mp4 to stream wireless.
I conducted a test yesterday to see what I can do to get the best video quality and sound from a BD movie ripped to main movie only M2TS file with HD sound and secondary AC3 track, english and spanish subs. This took approximately 45 min. to rip with ClownBD and AnyDVD HD in the back ground. I then proceeded to re-rip this file to M4V with the I believe to be good video quality and sound with Handbrake. It took approximately 4.3 hours to complete this process. I used Mediainfo and here's what I got:
General
Complete name : C:\Users\GusGus\Desktop\MP4 MOVIES\TERMINATOR 3 RISE OF THE MACHINES (2003)\TERMINATOR 3 RISE OF THE MACHINES (2003).mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1.57 GiB
Duration : 1h 49mn
Overall bit rate mode : Variable
Overall bit rate : 2 059 Kbps
Encoded date : UTC 2012-07-18 23:34:42
Tagged date : UTC 2012-07-19 03:45:54
Writing application : HandBrake 0.9.6 2012022800
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 49mn
Bit rate mode : Variable
Bit rate : 1 095 Kbps
Width : 720 pixels
Height : 288 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 19.173 fps
Maximum frame rate : 23.981 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.220
Stream size : 854 MiB (53%)
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1h 49mn
Bit rate : 319 Kbps
Maximum bit rate : 425 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -83ms
Stream size : 249 MiB (15%)
Language : English
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : ac-3
Duration : 1h 49mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Stream size : 499 MiB (31%)
Language : English
