Hi, I am a first time poster on AVS. I just purchased and set up a PG-A10X with an iScan Pro to replace my Sharp XV-Z1U. The picture is outstanding. However, I have a small issue that I think may be caused by the iScan. I am feeding s-video from my DVD player and my SD cable to the iScan, and am outputting RGB from the iScan to the A10X. I have the iScan set to RGB and Normal output. The A10X is set to input RGB (and sRGB) and signal 480P. Here is the issue: whenever I change channels on my cable TV, the A10X momentarily blacks out, then picks up the signal (overly bright), then (while claiming to be adjusting the image) snaps into a good picture. This all takes approximately three seconds. When I set the iScan and the A10X to component, the A10X momentarily blacks out, then snaps into a good picture (approximately two seconds). Is this normal behavior? I have searched the net and cannot find this issue discussed anywhere.
