I have a big collection DVD in iso files. What's the best way to stream to my iPad? |
You can't stream .iso to your iPad.
I know that, normally, I have to transcode them to other format, e.g. H.264, to use AirVideo or something like that. Is any way I can transcode on the fly while streaming to iPad. |
Air Video will transcode lots of different codecs and containers on the fly to your iPad, but not a ripped dvd.
I tried Handbrake. The problem is most of my DVD of educational materials containing chapters/lectures...Check in Handbrake's source Title dropdown again. Usually there is one entry that will have a time length that will equal the entire disc, use that one. |
Agree with gwpac, Handbrake should present you with the whole disc length as an option, usually right after the individual episode timings, if not then your dvds were poorly authored.
I want to be able to batch transcoding, one disc into one file.....and batch can be set up do many iso file one after another. |
If Handbrake doesn't present you with that whole disc timing then you are out of luck.
In that case, if streaming to your iPad is that important to you, your best option is probably to use MakeMKV to convert each disc to a single .mkv, then rely on Air Video to transcode them on the fly, on demand.
