So, I think I may scrap my mATX idea and go straight to ITX.
Using the "How to..." sticky above, I specked out a HTPC.
My question is, will THIS:
APEX MI-008 Black Steel Mini-ITX Tower Computer Case 250W Power Supply
...with this...
ZOTAC H55ITX-A-E LGA 1156 Intel H55 HDMI Mini ITX Intel Motherboard
fit with this?
Hauppauge WinTV-HVR-2250 Dual TV Tuner / Encoder 1229 PCI-Express x1 Interface
My main concern is the length of the card. At first glance, it appears quite long and may bump into something else. Has anyone else tried this build with this particular case?
I'm aware of the external options, like HD homerun (and the cablecard version), but if that were to be my only option, I might as well just go back to the mATX design I spec'd out.
The rest of the system is exactly how he spec'd it (I may throw in 4G RAM)
-Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
-G.SKILL 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-2GBNQ
-Intel Core i3-530 Clarkdale 2.93GHz LGA 1156 73W Dual-Core Desktop Processor Model BX80616I3530
...with this...
fit with this?
