After having several weeks of frustration with my RCA Phase III dish in January due to cold temperatures killing satellite reception on SAT A for my Hughes E86 and many useless hours trying to get help from RCA customer service, Directv and Best Buy, I eventually determined that there was a problem with the multi-switch built into the LNB array. When RCA would not issue a work order for the repair or replacement of the LNB Array (because cold clear weather with temperatures below 30 degrees, they claimed, was an "act of god" and not a normal operating parameter), I took matters into my own hands and bought three other RCA Phase III dishes with cash and tested their LNB arrays until I found one that was cold weather resistant. Then, I returned the other dishes with the defective LNB arrays for refunds. I thought I had the problem solved. I had no other problems this winter and early spring. That is until now...
Last night, less than 2-1/2 months later, the LNB array fails again. this time I've lost reception on all three satellites on the Hughes E86. Just this weekend I was getting 91 on SAT A, 89 on SAT B and 94 on SAT C and no one has touched the cables or the dish. My old Sony SAT-A2 still works. The signal strength is fluctuating wildly from 90 percent to 0 to 80 percent to 20 percent to 90 percent, etc., but it doesn't seem to be affecting reception on the old STB just yet. It appears that the multi-switch in the LNB array has gone by by.
I'm not up for dealing with the morons at RCA/Thompson anymore. Any recommendations or a more reliable Phase III dish? Is the Wistron Phase III a better choice? I'm ready to cut my loses and scrap the crappy RCA dish and maybe try to get Directv Customer Retention to reimburse me for the new dish. The RCA/THompson LNB arrays seem to fail every 2 or 3 months. That's hardly the quality I expect.
