This has been a really good forum to read, and this is my first post.
Well lets see how to being, I am a DirecTV customer, who was hell bend on getting a TiVo. Then I found out about ReplayTV, and now I am at the fork in the road. They both have great features, I am trying to find and old 50x series replay for the use of IVS but I wanted to know how well this really worked. I have contacted the TiVo company and they told me that I Can buy a regular TiVo and use it with my DirecTV, so the I would have access to all the HMO features. Then the only difference between the TiVo and Replay would be the 30 sec quick skip, which can be enabled on the TiVo and on the ReplayTV is called 'Quick Skip' instead of CA
My Question is well any advice when deciding between the two and How well does the over the IVS work when it comes to download shows I have read about a lot of connection failures.
Thank you all for any advice you may give,
Dave
Dave
