I have never used wall mounts before, and on the back of the jamo speakers there are two brackets that are for wall mounting (i assume).
I went to the local electronics store and picked up what they had for wall mounts the only problem is the ones I bought have 1 hole in the center where you would attach a speaker to the wall mount. Should I drill a hole into my speaker for this in the middle, make a bracket so I can use what the speakers already have, or remove 1 bracket from the speaker and move the other into the center so it can be mounted that way?
I can put up pics if that would help clarify this.
