1 - 3 of 3 Posts
Hello Forum.
I have a question regarding my new Jamo D600 subwoofer. I am very happy with the product, but there is one issue I would like to ask about.
I use the sub in my hometheater, Onkyo txnr838 receiver, Jamo D500 LCR.............my problem is, HOW do you store the setting on the subwoofer, so that you dont have to re-input all parameters when you (auto)turn on the sub again? I can enter all the parameters, but when I turn of my system and turn it on again....the sub has gone back to its 'normal' mode. The stored settings have gone.
I need the sub to store its last used mode, so that I dont need to put in all parameters again.
And yes, I have tried to press the 'select' button for 3sec to store.........the sub does not indicate in anyway that the parameters have been stored.
I would like to store a THX mode with a level of 5 and BGC at 6.
The manual is a kind of 'pictorial-type'......no explanations for anything.
Any info would be great. Thanks.
Discussion Starter · #3 · (Edited)
Ok......so you can't change the level in THX mode......level can only be changed from the receiver.......?
I will try the personal mode and see if it stores.........
In personal mode....are the 'slopes' the same as in THX mode?
1 - 3 of 3 Posts
