--A few M2/Crown DCI/N questions:
1-If i have a wireless wifi router and i connect my laptop to it (using wifi) then connect my two DCI/N amps using an ethernet cable to the router also will i be able to see both amps the same time on Audio Architect on my laptop?
Yes
2-Since i am using XLR cables for all my speakers for a long time. will something like a XLR to Phoenix cable work? i just want things to took neat without cutting any speaker cables and figuring out where everything is going to go. (Hosa Phx-206Fbulk 6-Inch Adaptor PHX3F to XLR3F)
Yes, as long as the pheonix connector the same. Some are different
4.My 3x M2's will all be behind an AT screen. do i have to raise the high frequency a little? i know some people like to lower high frequencies in their M2's (preference) so could this just maybe be ideal for most? the below is the effect of the screen on speakers from Screen innovations. most likely i will run MultEQ to 200hz or 300hz and let Audyssey not touch the rest.
''Typical impact on frequency response is well within the -3db range with a peak attenuation of -6db at 20kHz. This difference is easily corrected by most modern receivers with room correction.''
Let your ears decide. It is simple to make a correction filter in the amp and simply switch it on and off.
5-Any simple adapters/cables i could use that will let me turn on and off my three amps with my processor? don't want to walk to it every-time i want to turn it on or off.
I use a 12v relay that uses my prepro trigger. There may be some commercial options
