Thanks for the review!Well, I have had the M2s up and running for a few days now. Here are some impressions:
Pros:
They truly sound glorious. So clear, precise and effortless. I watched Godzilla and Alita Battle Angle and both movies sounded glorious in the new room. I also watched quite a bit of Dave Mathews and Tim Reynolds blu ray concert as the recording quality is top notch and this sounded SSOOOOOO good.
Cons:
These were not that easy to set-up for me. Certainly not the plug and play I am use to but nothing crazy difficult either. Totally worth it but here are some obstacles I ran into.
*8/600 DCI N amp is 20 amp socket with a different pin configuration so I had to buy converter to 15 amp (traditional grounded outlet pin configuration)
*Had to buy cheapy PC Laptop since my family is all apple laptops and you can't use the Harman software with apple products.
*Setting up the configuration in Audio Architect took me a few tries to make sure it recognized the amp on the network and to make sure I set-up the LF and HF plus bridged the amps correctly (once you do it the first time its easy after that but this is not Apple software experience where its so intuitive, the process is from 1972).
*I was getting some buzzing from the speakers and thought it might be a ground issue and I used a cheater plug to rule out it wasn't a grounding issue. Ended up having to play with the attenuators on the back of the amp to get the buzz to go away.
What room correction are you using for the speakers?
Sent from my SM-G960F using Tapatalk
