3721 - 3740 of 3802 Posts
Are 570s tall enough for that? Or using some kind of stands?
I have stands for the 530s, so I'll use the same for the 570s. The rears have to be a bit high to clear the back row so I think if anything, the 570s may be a bit too tall with the stands.
My 580s as side surrounds are just slightly above ear height when seated, so I know the 570s wouldn't be tall enough without a stand.
Sent from my IN2017 using Tapatalk
How tall are your stands?
While not a 5 series deal, I found the Arena 8IC in ceiling speakers are on sale (after adding to cart) for $99/ea!
That's pretty good! I got the 227's for that a piece, but once you factor in grilles and the mandatory backcans, the price quickly shot up past that per piece. Had I known better, I would have gotten the Arena's instead.
I thought it was a pretty good deal. I have the SP8CII currently, but they are just OK. Hoping these will be an upgrade.
Have you installed your 227 yet? I haven’t installed mine but I got a few more things to get but I went all out got the Xmc-2 3 older parasound amps doing 9.2.6. I hope to have it all installed by the end of Novembe.
allen
allen
Nope. Probably won't install until next year. The house we bought was tenant occupied and will stay that way until the end of the year it seems.
I am actually considering going for the 590s if/when they go on sale to replace my Emotiva T1+'s, which I would keep in a separate room. My only hesitation is that currently I have an ALL Emotiva speaker set, which this would break. But, I've read here where many feel the Emotiva C2+ is the perfect match for the 590s - so my LCR would seemingly be a solid set for my new bigger basement.
Then I also still need to buy 4 additional speakers to round out my 7.2.4. Currently I have 2 Emotiva E2 surrounds and 2 Emotiva A1s. A part of me wants to get the JBL 530s to use as L/R surrounds (big I know, but would pair with the 590s, and these need to be on stands anyway), then I would have the Emotiva E2s (rear surrounds?), and A1's (height or figure out a way to ceiling mount?) plus maybe another pair of A1s or something else. OR, I use another set of 530s for rear surrounds and figure out a way to repurpose the E2s and A1s for Atmos.
Appreciate any feedback on this concept...
I tried my 590s with a 235c and a 520c and ended up using the Emotiva C2. No regrets.
I was originally running my 590 with klipsch side surrounds and a pair of klipsch rp500m I think and it really sounded good. The 530 went on sale and I bought two pair I really can’t tell a difference but I really liked the klipsch side surround S502 I think. I thought about putting it back in my system but I know I have the best match with my all JBLs system.
Allen
Allen
I'm using 530s as surrounds and before that I had Elac B6.2s. I agree that surrounds aren't very important, but like you want to do the 'best match'. It's why I still have my 520 in a box, just in case some future wizardry makes the full series 5 better than using emotiva center
  • Like
Reactions: jlm86
any reviews on the 570s
x2...i an anxiously awaiting peoples thoughts .. i might try to grab a refurb pair at some point...
Sorry guys, I set one of the up for the photo and then never plugged it in. Work has been a bear. Got a 3 day weekend coming up. Will have to do some listening!
awesome .. i'm looking forward to your thoughts
the 570 (as i recall) is a very close cousin to the 530 .. same mid driver , but 2 of them in a larger cab.... i would assume they are very close in sq......
Some have stated the 530 bookshelfs run out of steam when pushed with some port chuffing. I wonder if the 570 would be a better consideration.
