1 - 20 of 7880 Posts
Discussion Starter · #1 · (Edited)
Product Page-
https://www.jblsynthesis.com/produc...plifiers&dwvar_SDP-55-_color=Black-US-Current
RRP $6000
Very exciting product
No hardware updates for channel expansion - you have to move up to the substantially higher 65 or 75 processor model ranges.
Late this year/early next release date.
From a Sound & Vision article the HDMI board will be upgrdable to HDMI 2.1-
https://www.soundandvision.com/content/jbl-synthesis-introduces-two-new-immersive-controllers
Further, the HDMI board is removable and replaceable so it can be easily updated to full HDMI 2.1 capability when the format is finalized, ensuring owners aren’t abandoned by a technology upgrade.
Spec Sheet Here- https://www.jblsynthesis.com/on/dem..._JBL Synthesis SDP-55 Spec Sheet_EN_V2_LR.pdf
The JBL Synthesis SDP-55 is designed to ensure exceptional performance without compromise. With best-in-class audio and video signal integrity,
16 channels of native processing, Dolby ATMOS®, DTS:X®, Auro 3D®, IMAX® Enhanced, Dirac Live®, Logic16™, Network Streaming, and Dante®,
the JBL Synthesis® SDP-55 delivers a powerful, sensory-rich experience with unrivaled flexibility.
Control your favorite content over Ethernet or Wi-Fi with Chromecast® built in, Apple® AirPlay 2™, Roon® the Harman Luxury MusicLife app, play
directly from a USB flash drive, or stream with Bluetooth.
An internal configuration page, integrated Dante, IP, IR, and RS232 control and a robust Zone 2 make the SDP-55 an outstanding choice for a
broad range of applications.
Features
Immersive High Resolution Sound
16 channels of discrete high resolution processing with 4 user configurable channels enable a plethora of set up options for Dolby Atmos, DTS:X and Auro 3D immersive surround sound applications.
Dante Network Audio
Bridge the gap between residential and commercial applications. All 16 channels of processed audio, plus Zone 2 can be routed on a single CAT5e or CAT6 cable over a standard network. Dante is easy to set up and compatible with Dante enabled JBL Synthesis amplifiers.
IMAX Enhanced
IMAX Enhanced certified AV receiver, featuring DTS:X immersive audio decoding that is optimized to properly reproduce the full dynamic range of IMAX theatrical sound mixes available in IMAX Enhanced content.
Network and Bluetooth Streaming
Control your favorite content over Ethernet or Wi-Fi, Chromecast built-in, Apple AirPlay 2, Roon, the Harman Luxury MusicLife app, play directly from a USB flash drive, or stream via Bluetooth with aptX HD.
Balanced XLR Outputs
A transformerless balanced output of 2V RMS (max. 10V RMS) ensures ample gain and common mode noise rejection.
Cinematic Video Experience
Dolby Vision, HDR10+, HDR10, HLG, HDMI, HDMI2.0b with HDCP2.2, 4K “Ultra HD” as well as 3D video capabilities are built in.
Designed for the Integrator
With an available rack mount kit, Dante, eARC and an internal configuration page, Dirac Live, IP, IR RS232 and iOS and Android App control the install, set up, and calibration has never been easier.
Logic 16
Logic 16 will up-mix any input source from mono up to 15.1, including all Dolby formats with natural astonishing 3D sound. In addition, Dolby, DTS Neural:X, and Auro 3D upmixers are on board.
CEDIA Videos-
From the 8min mark-
and
and
- Personally I hope the SDP-55 can playback Multichannel DSD from Roon over network like the Trinnov can. Also Qobuz also has multichannel album listings for playback via Roon.
- Also a backlit fully featured remote for those of us whom don't have an automation system.
Thanks to the theblackangus for the following list-
Things still waiting on implementation:
Dirac Bass Control
DTS:X Pro
Logic 16 (Still in development)
Future Upgrades:
HDMI 2.1 (unclear if this was actually promised or just said was possible but undecided)
Things still broken:
Auro 2D or 3D mode is much lower than when played in stereo or 16ch stereo
Abilitiy to play a DTS CD and get sound
Auro Native - The less common Auro 13.1 and Auro 11.1 (7+4) formats do not work.
3D: OSD missing grey background in 3D and 3D 1080P reported as 1920*2205 (3D itself works fine)
DD+ 1.5mbit (AKA Universal HDDVD) via Kodi does not work - All other DD+ issues I previously had have been fixed
Dirac with 24/88+ Audio and DTS processing modes does not work - Other have reported this issue
No analogue audio working in main zone with V1.28 - This works for most people and does not really effect me as I only really use analogue in Z2 where it is fine.
Corrupted OSD - If I programmatically start my TV and the AV40 at the same time the OSD corrupts - Adding a 1.5 second delay to starting the AV40 fixes this completely.
Dirac:
Enable dirac,play Atmos,the center channel lost dirac
Enable dirac,left and right surround and right back surround modification delay is invalid
Enable dirac,the sky speakers and front speakers have a significant delay difference
Enable dirac, modify the delay of the left front sky channel will affect the delay of other channels
Enable dirac, it often causes popping sounds[/quote]
This is firmly on my radar. I also was looking at the HTP-1 but I have JBL speakers and crown amps so this looks very promising to me as I am a huge JBL/Crown fan.
Looks like a Trinnov. Could be exciting.
I suspect Trinnov in front, Arcam behind the faceplate. If Logic16 works out as a music upmixer, though - who cares!
I was penciling in the HTP-1 too but I'm glad it's going to have competitors. It looked like it was going to be on an island. I don't count Emotiva - they fail on usability, and sonics because they don't include a competent upmixer for 2-channel music. Maybe this pressure will also get D+M to up their game with thoughtful multisub support and improvements to the Audyssey app, in their next gen pre-pro, and Anthem to work on multisub support and Auro.
This looks very exciting. HTp-1 was also on my radar, though, at first glance, this looks like a real winner. Was not expecting that price either.
Does JBL have 'street' pricing or common sales that might have this thing end up ~$5k in a year or so?
I am pretty confident you will be able to get this below MSRP from a vendor. I don't think they run sales per se...at least not that I have seen.
Interesting, any Dante enabled amp's that doesn't cost a fortune?
Premium Member
I'd really like to check out the Dante interface on this, I know Dante's coming to the Altitude 32 next year but this is an exciting advancement especially at this price point.
Premium Member
QSC, Q-SYS Core DSP's will also accept an AES67/Dante data stream and you can then connect any amp downstream.
And what is Dante?
It is simply to send audio over IP. In other words you simply connect standard cat5e cables and switches between your processor and amp's/active speakers. It has been used in pro audio for quite a while.
Premium Member
And what is Dante?
In its simplest form its Audio over TCP/IP, Dante is just one flavor of the protocol that is probably the most popular.
  • Like
Reactions: Mashie Saldana
Sheesh, who would have ever expected this price point? Still a bit too much for me, but will work just fine for many in these parts.
Looks like peasants like me could have something to save up for on the used market.
James
If this can handle the EQ and x-over for my M2s and multiple subs (at least distance and delay) then at this price it certainly beats out my current target, which is saving for the Storm Audio piece. While I've been told by my dealer that Storm claims to have the M2 profiles "close", I don't want "close" if I can get "exact". Plus, Storm wasn't exactly willing to work with me to let me test how "close" it was and that took most the wind out my sails. Glad, though, because this unit may be a better match for me and at a better price, too! I don't need the higher channel counts of the Storm. Plus, after some manual tweaking, I have been enjoying the sound in my room so much that I haven't even set up Dirac on my current NAD.
I have such a simple 2-channel + 3 subs setup that most of this stuff is overkill. There's not really much I want at this point except to get rid of my hissy Crowns because the only complaint I have is noise. I have been trying to find the most "pure" way to have all M2 EQ/x-over done in the digital domain with a single D->A before the power amps, for the least amount of money, and this may fit that bill!
Not sure what amp you have but I just got three M2s with a Crown DCIn 8/600 amp. I had hiss the first couple of days as I was setting everything up but was able to adjust the attenuators on the back of the amp and its all but gone (have to be 1 foot away to hear it...before you could hear it from the seat). Not saying we have the same issue but if you haven't tried that path yet, maybe it will help?
I have the iTech 5000s and my sensitivity is set as high as it'll go from the front-panel adjustments -- I believe it's 4v. I have heard it'll go higher in the web interface, but I don't know if I can go much higher than 4v before I have other issues (e.g., clipping my NAD's output stages trying to drive it). I have found the sensitivity adjustment to make a bigger difference than the gains with regard to the noise I get (like a whine / hiss -- it seems self-generated in the amps), but I also have the gains set fairly low and it does help as well. When I was mucking with the gain/sensitivity, I found some "odd" combinations that would make the music sound...unnatural. Hard to describe, but I landed on where I am with a bit of experimentation and trading noise for the peak level I could produce without clipping the outputs -- maybe I could do better if I gave it more time, but I need to work to pay for this hobby instead, lol, so I rather spend the limited time I have enjoying than tweaking.
That said, I can only hear the hiss from my seats if it's late at night (lower noise level in the house) and I am focused on listening -- and only then during quieter content, but, usually that's precisely when I hate it most, so.... Honestly, it's a nit, but it's the only one I have and...I'm dumb / crazy enough to "need" to fix it, lol. Maybe, with further adjustments, I could improve the situation, but...even if I could, I wouldn't hate getting rid of the extra A->D D->A in the Crowns and having more flexibility in choosing my amplification. Especially since I can get something fan-less and put it in-room on an equipment stand, getting rid all the 60 foot speaker and signal cables running from my storage room to the media area of my basement!
Anyway, I'm pretty much just trying to justify an upgrade strictly to improve signal-path "purity", lol. Everything else is just a bonus. But, since my own personal "ideal" signal-path has always had the AVP doing everything (including active x-over) in the digital domain, with one D->A for amplification, I've been looking at ways to get there for a really long time. Unfortunately, for the, arguably, minimal improvement it brings (to all but my mental happiness about the signal-path being "ideal", lol), I felt it to be cost-prohibitive. So, if this unit can get me there without my wallet taking a $15k+ hit, just for the AVP, which is pretty much what it'd take right now, then I'm much more willing to start opening it up, lol.
Which NAD? It looks like their cheapest Dirac AVR is a poorly measuring device, so noise may be originating from there. That could also explain your weird sounds with different gain/sensitivity combinations.
M17V2 -- the noise is not originating there, I can disconnect the XLRs and the noise does not change. Plus the NAD isn't the only pre I've had connected to them and it sounds better than my previous Denon 4311ci + CleanBox.
As for the "weird sounds", I don't know if that's how I'd describe it. It wasn't like there was some crackling or something (I'd attribute that to clipping). It was more like the audio..."pumped". I can't really describe it, but I didn't like it. Full disclosure, though, that happened when I was tweaking the gain/sensitivity to try and remediate (as best as possible) a ground-loop-hum I was getting when running the Denon's single-ended outputs to the Crown via an XLR adapter whilst awaiting the arrival of the CleanBox. So, I probably landed on some odd combinations that may be atypical. Certainly the constant 60hz hum didn't help the situation, so...it's possible it was in my head, lol. But, the "lesson learned" for me was, don't mess with the gain/sensitivity too much. Which, is why I haven't tweaked further than where I landed way back when to further reduce the amp noise, because it may cause other artifacts I don't like.
edit: P.S., I know there's a "proper" way to set gain and sensitivity through measurements. I even have a volt-meter, so I could probably set it up "optimally" if I cared to take the time. It's just "optimal" may leave me with more amplifier noise, and I just don't want to muck with it anymore. Really, I just want the amps gone...they are unnecessarily powerful, noisy in more ways than one, and do more than I want them to (A->D for EQ/x-over). The minute I can get rid of them in a cost-effective way, I will. Until then, I enjoy the hell out of the setup...I'm just under no delusions I can't make it better in this aspect.
That said, before I dump the money, I probably will at least try to further increase the sensitivity and mess with the gain and see what happens. But, I'll probably still prefer having the whole setup in-room with me than running 60' cables just so I don't have to listen to blow-dryers, lol. Heck, maybe I'll even go with some crazy Class A's so I have some heat in the basement, lol! This setup was much more acceptable in my last house -- the amps sat in my basement directly under the speakers, the floor kept the fan-noise out, and I could use much shorter wires punched through the wall. I also sat further from the speakers, so the amps' noise-floor was not even slightly audible. But, now, it doesn't work as well.
I need to get over your place. I have the tool to quickly and easily set your gains to ensure the whole chain is optimized. Optimal is less amp noise, not more.
I'll PM you to get your new address and let's do it within the next week or so.
