Very nice considering it’s probably based on Arcam hardware. Any idea of the price yet?
Also I'm surprised DTS:X Pro isn't mentioned as it will be in the SP-55 ...
You are correct, no idea where I got it from.Where do you see that?
All I see is DTS:X3D, which I've never heard of, but maybe they're the same thing.
Ouch, there's always something getting in my way.MSRP is $7500
HDMI jacks look upside down compared to how I've usually seen them.Here are some nice close up pictures from the JBL website.
Well spotted, maybe that one is for the Australian market.HDMI jacks look upside down compared to how I've usually seen them.
Exactly.Isn't G only Class A/B with a changeable rail voltage to improve the energy efficiency of the A/B a bit?
Right, class D converts the signal to pulse width modulation (like the way audio is carried on FM radio).I don't think it's class D.
I wonder if JBL didn't mess things up a little when they released this and the SDA-7120. Both are 7ch which means you can't make a very tidy 9.1.6 setup using only two devices connected with a cat5e cable running Dante between them as it will be one amplifier channel short.
The thing with Dante is that it isn't a 1:1 ratio between port's like in the analog nor HDMI world. Just connect a network switch in between and you can run 15 Dante mono blocks or 15 Dante active speakers if you so wish.I think you will be fine. There are two Dante network ports on the receiver allowing to connect to both the 7 channel and 2 channel power amps.
That's pretty cool! This is kind of a milestone bringing it to a mid-level SSP. Hopefully others follow suit.The thing with Dante is that it isn't a 1:1 ratio between port's like in the analog nor HDMI world. Just connect a network switch in between and you can run 15 Dante mono blocks or 15 Dante active speakers if you so wish.
Logic16, Dante, and Auromatic, as well as a much better looking case. I don’t know if Arcam has the Harman curve available or if either have the speaker profiles for Harman speakers like the SDP-75. Anyway, I doubt people buying Synthesis systems care about a $1,500 price delta considering the added features.It is an ARCAM AVR30 with Logic16 and Dante.
MSRP $7,500
Oh well...that would've been a winner.Harman rep said the SDP55 will not have the speaker curves.
