I used Ulead MF5 to convert some footage from HDV-NTSC to MiniDV-PAL and the result looks jittery.
I thought the field dominance might be the issue... (HDV - upper field first MiniDV - lower field first)
So I tried reverting the field dominance but the result played from the camcorder on a PAL CRT screen looked jittery again and I can't make up my mind if better or worse!
1. Does Ulead MF5 correct for these when converting?
2. Any ideas what might be my problem (could it merely be the 30fps to 25 fps conversion)?
