I just moved from one condo to a larger condo.. My old condo I was ceiling mounted and placed on a flat wall. My new place has a "cuby" for the television, I am trying to project into this area. Distance from wall to wall is 16ft.. distance from projector lens to wall is 15ft. "Cuby" cut out is 81 inches.
I have posted some pictures so you can see my setup.
I cannot figure out how to "shrink" my picture so it appears in posistioned on the wall and not carrying over to the side walls of the cut out. I will have to get black velvet to line the walls because the reflection off the wall fades out my blacks.
I've tried to keystone it, and it worked.. but the right side of the screen is 5inches shorter than the left.. and it looks as if you were watching from an angle. Also motion is stretched.
Please advise.. I need my tv back
