Just purchase Samsung SIR-T151 Need help
349 Views 4 Replies 2 Participants Last post by  SGKishJR
Just Purchased the Samsung SIRT-151 at soundcity.com for $348.00 and had a question about the output select button.The owner's manual states that the 1080i setting is for a 16 x 9 format television as well as the 720p setting.I will be purchasing a xbr36 800 " 4 x 3 "and i am confused on which setting to use.I am recieving SDTV and HDTV OTA from Philladelphia ,"ABC,CBS,NBC,FOX,UPN,WB".
Thankyou, Steve
Current set-up
MyHD mdp-100
CM 3023
CM 7775
Status
Not open for further replies.
1 - 5 of 5 Posts
Thanks for the advice jeffthurmont.I would like to keep my set-up simple for my family.My first thought was to set resolution switch 1080i ,plug the component output to the xbr36 800 and the TV would switch between 16 x 9 and 4 x 3 programming.I guess I'll have to experiment when i get my TV.
Thanks,Steve
It would really suck if I got to change the resolution switch between 1080i and 480p depending on what program I am watching. The switch is located behing the STB.
Thanks ,Steve
Use the 1080i output select and make sure your 4:3 Sony XBR has the vertical anamorphic squeeze enabled when you use HD.
Thanks everyone for your help.Unfortunaly I do not have my xbr yet to try these config's.I got alittle worried when I was reading the owners manual on the resolution setting's.I really got to keep the set-up user friendly for the family.My wife thinks i am nut's spending all this money and time trying to get OTA.She will understand when she watch's CSI and other HDTV programming.
Thankyou, Steve
1 - 5 of 5 Posts
Status
