I am trying to process all the information needed before starting the calibration process, but i’m still confused on what is the concrete step-by-step process.
As such, i’m trying to understand and compile a step-by-step process so I have a full understanding before starting.
The goal is to perform an Autocal calibration of a JVC 7900 (600H) with a xRite i1Display Pro (EODIS3), using the patch described in “
Using Alternative Meters for JVC Autocal Software”
The following shows the steps i compiled by reading the information presented in this and several other threads.
Please note that i’m not sure what I wrote bellow is accurate, as its my own interpretation of the data.
Step 0 – Meter Position
Given that I’m using an EODIS3, meter should face the screen, reading the center portion of the screen.
Based on the images I saw, the meter seems to be placed in a slight angle towards the screen, at about 30-50 cm of the screen?
Step 1 – Gamma calibration
Projector preparation (Based on
@Dominic Chan suggestions
here):
1) Set iris to 0
2) Zoom to smallest image size
3) Adjust the sensor reposition/angle to get the maximum reading
4) Use Normal Quality (20 steps) instead of High Quality (33 steps).
0) In the settings (last option in the main menu), select gamma + color. Select 20 steps (per Dominic suggestion)
0a) Go to calibrate
1) Select a Standard color profile, iris to manual, switch all processing off, including CMD.
2) Select Gamma 2.2
3) Select 6500K color temp
4) Run the calibration.
5) Save the calibration, save the backup file (with INIT in the name) in a safe place.
Questions:
1 - Are the steps above correct?
2 - Given that in the next steps i want to calibrate a REC709 (Filter Off) and P3 Profile (Filter ON), how does it impact the steps above?
