501 - 520 of 4669 Posts
Premium Member
Discussion Starter · #502 · (Edited)
I re-ran my auto-cal last night and I think the results are infinitely better than my first try. In fact, I dare say it’s about the best image I have ever been able to achieve. Having done it a second time, and with Manni’s patient coaching, I now realize how terribly wrong I did it the first time.
My gamma no longer has that weird “S” curve. I can now watch Deadpool (HDR) without that sub-burnt look that I previously observed in some scenes. And while Black Crush is greatly diminished, I can still see it to some extent (in Deadpool anyway and practically non-existent on Revenant. Don’t know what it is about the the Revenant but that movie looks the best of all.
I started off running a full gamma and color calibration in NATURAL Picture Mode, Standard Color Profile, 6500K Pre-set and Normal Gamma. All processing turned off, Low Lamp, Iris manual and fully open. After saving the results, I ran a color-only calibration for the various Iris settings (-5, -7, -9, -11, -13). I also ran an identical color-only calibration in USER 2 for Manni’s REC709 NF custom profile, at the same Iris intervals.
I then ran a full gamma and color calibration for SDR BT2020 in USER 3, REFERENCE Color Profile, 6500 K pre-set, still in Low Lamp, followed by a color- only calibration for USER 3, BT2020 Color Profile, at the various Iris settings.
For Natural, REC 709 NF, and SDR BT2020, I am using a custom 2.4 Gamma correction with +2 on dark gamma for a BT1886 curve.
After completing the above, I then switched to HIGH LAMP mode, Iris fully open, and ran a full Gamma and Color Calibration with User1, REFERENCE Color Profile, Normal Gamma, Manual Iris, all processing turned off. After saving I ran a color-only calibration of User 1, JVC’s BT2020 Custom Color Profile, Manual Iris full open, then at -5 and then at -7 etc.
When I was done with the JVC software/autocal/Spyder 5, I switched over to Chromapure/iD3 Pro and calibrated 100% white. As you can see in the attached images, the DE was around 3 so it didn’t take much to tweak it down to .3 DE.
Can't say for sure if my Spyder is a good sample so I will leave that to Manni to pronounce it either way. Like I said, my image is spectacular so it can’t be all bad. The only thing I would want to improve right now is to correct the small bit of occasional black crush----which I can only detect in Deadpool so maybe it's just that movie.
I am attaching some screen shots for the usual suspects to review. There are two things left for me to do:
(1) Figure out how to integrate my HD FURY so I can try SDR BT2020 and
(2) Figure out how to use the Sony Test Patterns and determine where to clip white in HDR.
Kevin said it’s pretty simple using the apple app so we shall see.
A hearty thank-you to Manni and all the other helpful folks on these forums. I think a lot of us Novices would have given up on our BCMs if it weren’t for such folks.
Rick
You're welcome, and I'm glad you got results you're happy with. :)
A few comments:
Your Spyder seems to be pretty accurate as far as 100% white is concerned. A dE of 3 at 100% white compared to the i1d3 is pretty good, although there is no way to know how accurate the i1d3 is, could be less, could be more than that, impossible to know without a reference meter. However, the i1d3s are usually very close so it's in the ballpark.
Your rec-709NF profile in custom 2 measures a bit undersaturated on the green-red side. Again it's impossible to know if it's the meter or the calibration. It shouldn't be bothering you as it's very minor, and is probably less visible than the slight oversaturation (and likely worse tracking) in standard.
Re using the Integral to get BT2020, it should be as simple as setting it to custom mode 10 and setting the JVC to your SDR BT2020 user mode (at least with the Panny, no idea with the Sammy), but if you have any issues post in the main thread or in the HD Fury Integral thread for help.
Re iris positions, I've stopped to do all of these because in my opinion the improvement doesn't justify the time spent. Plus you are wasting time recalibrating color for iris settings whihc are too close to each other, for example -5 and -7, likely overriding one with the other. Harry identified four ranges, 0, -4, -8, 12 and I used to us 0, -5, -10, -15. Neither are fool proof on the new JVCs, because the biggest difference is between -3 and -14, so whether you do -15 or -12 you won't be accurate if you move the iris above or below -13. I've given up on this. I just estimate the iris setting / lamp mode I need in each mode (-3 low lamp in SDR rec 709 or SDR bt2020, -7 high lamp in SDR) and I only autocal that setting. I'll redo an autocal when I need to open the iris in a few hundred hours, or every 500 hours or so. This change is detailed in post 9 & 10. Of course nothing should stop you from running a color autocal for each range, but at least only do it once per actual range (which you will have to identify on the new models), not so close that you override the last one.
I did try to look for ranges last time and apart from the big jump between -14 and -13 (which is when the dual iris kicks out for the first time I think), I couldn't find any consistent boundary, and the errors where quite low anyway, I doubt they would be visible. That's why I gave up doing this. which I don't find sustainable now that we have not one (SDR rec-709) but three modes (SDR Rec-709, SDR BT2020, HDR BT2020) to calibrate.
Anyway, good job! :)
Rick
How can you check the shape of Gamma D? The software only shows the corrected gamma for the one selected when running the calibration, no? Or is the image supposed to show an average of all gammas at the same time?
Premium Member
Discussion Starter · #505 ·
You can't measure gamma D without a pattenrn generator able to switch the PJ in HDR mode and a way to use an EOTF correct for a projector, which calibration software haven't sorted out yet (Calman should hopefully come up with something this month so we can use 5.7 and the Integral with a projector).
I assume atabea has used Chromapure with his i1d3 to read the Gamma D curve in SDR, which isn't relevant.
The Gamma D / PQ gamma curve can't be read without the correct tools. AFAIK, they are not avsilable for projectors yet.
Thanks, Manni, for your (always) informative reply. The next time I run auto-cal I will remember not to spend so much time on too many Iris settings. I find that is the most tedious part of the process. Otherwise, I am ecstatic with the results.
:D
Quick question, i finally got back to my pre calibrated settings and am now going to do the gamma, under natural, standard, 6500k,gamma normal. The filter is normal. Is this where i turn filter off? If so how, I'm double clicking it but not getting a drop down option.
I believe if it says "normal" it is already off so no need to try to turn anything off. Maybe wait for Manni to confirm.
Premium Member
Discussion Starter · #509 ·
Yes, filter normal means filter off.
You don't need to touch the filter setting, just leave it at whatever your user mode needs.
thank you guys.
here are my new results, hopefully better then the first go around.
so first three are the typical gamma, color, white after doing the 33 point calibration, per phase 1. natural, standard setting
then i did phase 2w/ 0, -5, -10, -15 cmd off/low no attached pics
my final thumbnail is my final color calibration, user4, 709nf, 6500k, 2.4 +2, cmd low, -10 iris
hopefully better then last time
Premium Member
Discussion Starter · #511 ·
thank you guys.
Looks good :)
I was excited to run my first autocal and post my Spyder5 Pro results, but it appears that I cannot get my RS500 on my network. I tried multiple cables, multiple connection points directly to the access point, DHCP on, and DHCP off with multiple static IP addresses. Nothing has worked despite both the orange and green lights being lit on the projector's network port. I'll need to do some troubleshooting with JVC to see if the network port is bad on the projector and then I'll circle back with my results.
If you go into your router...can you see that the JVC is connected and has an IP address?
Thanks Dave and Seegs. I just solved the problem. I had to change the third-to-last static IP address digit from 0 to 1 and that did the trick. Now my router sees it! I'll post my autocal results sometime in the next week, and I'll post how the Spyder5 performs compared to my i1D3 in Calman.
I ran my first autocal tonight with a Spyder5 Pro. I did gamma + color for standard and then did color only on Manni's Rec-709NF profile. I think everything looks good. Next comes the fun part of seeing how accurate my Spyder5 is. I'll check on that this week and report back.
I could not have done this so efficiently without Manni's excellent guides in the first several posts in this thread. He is also correct that the standard profile is oversaturated. I am trying to see if I can get away from my Radiance entirely, so I used his Rec-709NF and it is spot-on (according to the Spyder5, anyway).
Premium Member
Discussion Starter · #520 ·
Looks good gamut-wise, although I assume you took screenshots after the rec-709nf color only calibration, which didn't touch the gamma as it's a custom color profile (see the dash after gamma in the first screenshot, that means gamma calibration wasn't applied).
The gamma looks perfect though, so it looks like the former run with standard worked well.
Yes the rec-709nf gives results as good as the spyder 5 allows. It needs to be checked, but even if slightly off the near perfect linearity should be an improvement anyway.
Good job!
