Go it was long since we had not talked about JVC, the manufacturer will present in autumn 2015 CEDIA DENVER its new range homecinema, these 3 new models JVC DLA 12 1080p resolution with I-Shift and finally, a native 4K !! ..... If this is the model 4K, nothing too exciting you say ...... nay no mistake, the three projectors will be equipped with a laser source beam and dual blue phosphor wheel .
First the DLA-LAHC6 should be marketed to € 5,999, the second DLA-LAHD8 to 7999 € and finally the only model will be the native 4k JVC DLA-HD10 to 9999 € also laser.
Finally we will be able to talk on the forum JVC and especially we bet they have found a solution to the low point of their range lights ....
source :
http://www.projection-homecinema.fr/forum/topic/509-jvc-dla-lahd1-hd8-et-hd10-nouvelle-gamme-homecinema-laser-4k-native-9999%E2%82%AC/
source :
