1 - 1 of 1 Posts
I bought a cheap RS20 to replace my old one with the pink stripe issue.
The image is fine, but when the projector is cold, the lens shift doesn't work.
After about half an hour it seems to work fine.
Any idea about what could cause this issue and whether a fix is likely to be expensive?
Also, does anyone know where to get replacement feet from?
1 - 1 of 1 Posts
