Status
Not open for further replies.
1 - 3 of 3 Posts
Hello all. I just purchased the new JVC dvd player. I have it hooked to my receiver by the optical digital cable. Does the SPK setting/Expert have any effect whatsoever?? Or only if i use the analog connections on the back of the player, because the player has a built in DD and DTS decoder? For best results, what should i set all the audio selections at? Or is there a special mix and match i need to do to get the max sound from my player? Please help, thanks
Discussion Starter · #3 ·
On the digital output selection, does it make a difference in quality between the Stream/PCM and the DolbyBigital/PCM selection??? I noticed i can play Fantasia DTS when i pick DD/PCM. Keep in mind my receiver has only a DD decoder and not a DTS.
1 - 3 of 3 Posts
Status
