Status
Not open for further replies.
1 - 1 of 1 Posts
· Registered
Just curious to see if anyone out there is using the Kanam HT200 Case IR Module. I just bought it and am trying to get it up and running. My plan is to actually use a Pronto remote to control simple PC functions (WinDVD, MyHD tuner card).
The main problem, though, is that the IR Module seems to be of exceptionally poor quality. I've been using IRAssistant and Girder to try to read IR signals from various remotes I have. While the module receives signals, they are not consistent. As an example, I can press the same remote button 5 different times and get 5 different numeric strings representing the command.
Has anyone had any success with this product?
1 - 1 of 1 Posts
Status
