I have a problem surfing up and down with the channel button--on the remote as well as on the side of the tv. I can directly dial a channel by punching in its number but cannot step up or down once I directly dialed a channel.
My set-up: running cable straight into my apt., then splitting signal with one side going straight into tv (i.e. analog signal) and the other side going to the digital Motorola cable box which provides me my hi-def signal (plus any other available station in digital format). Of course, the component connection coming from the cablebox and going into video 5 can only be dialed with the cable remote (and, by the way, surfing with the cable remote in video 5 (i.e. digital signal) is possible. But on the other, analog side, I should be able to surf up and down with the Sony remote or tv's side channel button, particularly since I can directly dial any channel with the remote.
What's my problem? Did I forget something in initial set-up? Do I have to punch a button on the remote--however, don't forget, I cannot surf with the tv's side channel button either.
Help would be appreciated.
Wolfi
Wolfi
