I made my own movie poster frames using metal frames from MJDesigns (the kind where you buy two 40" legs, two 27" legs and put them together) and glass bought from Home Depot. The problem is that the posters sag after a week or so.
I then bought foam backing and glued the posters to them using spray adhesive. Success! At least for about a month. Then the posters started to have bubbles and wrinkles in them.
My next choice is to buy one of the frames that hold the poster on all four sides, like a Bass Loc frame. Will I have the same problem with sagging? What is the best place to get a frame like this? I don't want to pay more than $100.
Glenn
Glenn
