Status
Not open for further replies.
1 - 4 of 4 Posts
I am about to pull the plug on a 5900 changer so that I can use it with Mario's DVD Lobby (which now has a plug in to support it)...
But I want to make sure that I get an updated version of the 5900. I called Kenwood, and as expected, they had no idea what I was talking about. They have not had "any updates" to this product, I was told. Nor surprise.
So...does anyone know how to tell if it is upgraded or not?
Discussion Starter · #3 ·
thanks...I did get an answer
anything above 30400400 serial number...
it should also have a 3 on the bottom of the box.
Tony
That serial number thing is not necessarily correct, check the thread, I believe that if you hold stop and press 0 on the remote it will dump the three ROM codes, they should all start with a three.
Tom
1 - 4 of 4 Posts
Status
