Hello i am new to the forums...
I have a Kenwood KA V7700 amp ..
and 2x B&W DM 600
and also a Jamo center 100
And a DI -Box David 310 subwoofer
The problem is that there is a fuzzy noise coming out of the LEFT when the center is on .. but if i turn off the center it doesn't do it unless the volume is turned up high
I check the connections and stuff and there is no problem with the wiring.
I also swapped the speakers left and right and it still had the same problem.
I don't know hat is the problem .. But its very annoying when the movie is in a quiet scene and you hear static noise ..
Anyone know what is the problem?
Also if someone has a extact same amp,speakers,sub .. can you find a online manual, i can't find it anywhere .
and 2x B&W DM 600
