1 - 2 of 2 Posts
I have an older kenwood home stereo KC 105, that has stopped working, when I hit the power button on, it flashes 3 times and keeps doing it over and over. I have searched the internet for help but no luck. I did take the cover off and could not find a fuse. Does anyone have any suggestions or a shop in Chandler Arizona that might be able to help?
Kevin Smith
Banned
Do you still have the manual? Sounds like a protection mode from a fault. Check all your connections to make sure there's no short. Try unplugging it for a bit (cheap reset method). There may be a reset routine in the manual. Might be time for a replacement rather than repair, check the costs.
1 - 2 of 2 Posts
