1 - 2 of 2 Posts
After extensively going through every possible diagnostic (including hardware such as the HDMI cable, possible settings on the tv itself, and customizing IR codes) with Logitech support, I have not been able to control the TV functions for my XBR series Sony HDTV (Model KDL-52XBR5) on my Logitech Revue keyboard controller.
Does anyone else have an XBR series HDTV that they have been able to control with the keyboard controller!? Specifically an XBR4 or XBR5 series??
When I enter the model number, google acknowledges it so you would think that the pairing would function. Apprently not.....
This is a very annoying quirk as I want to be able to control all functions from the keyboard controller!
Just about any sony codeset should work fine since all sonys have used pretty much the same codes across all models for years. Try a different model like the KDL-46XBR5 or even the KDL-50A3000.
1 - 2 of 2 Posts
