1 - 20 of 21 Posts
Hello fellow forum members, i am planning to buy new klipsch 5.1 HTS. I don't have big budget but still wants good HTS. i have shortlisted some of klipsch system are as follows :-
1. Quintet Home Theater System 5.0 + SW 350 Sub. ( http://www.klipsch.com/quintet-home-theater-system-2012 )
2. Synergy B-20 Home Theater System. ( http://www.klipsch.com/b-20-home-theater-system )
3. HD Theater 500 Home Theater System. ( http://www.klipsch.com/high-definition-theater-500-home-theater-system )
Please tell which system suits best with Denon AVR 1612.
Any of those systems will work fine with that Denon receiver. Personally I would go with the Synergy line as that is going to provide you with the best quality audio out of the three systems that you linked to.
Bookshelf speakers are great for those on a budget as well as those who really don't have the room for floor standers in their room. The biggest drawback to bookshelf speakers is that they can't hit lower frequencies with as much authority as their bigger counter parts and they sometimes don't have as smooth of a mid range. Having said that, you are looking at a 5.1 system which has a subwoofer included. This will take the burden of carrying the low frequencies off of the bookshelves and allow them to play the rest of the frequency range with more authority. I just happened to look at Klipsch's website to see what kind of price difference there is between the bookshelf and floor stander systems and I personally would stick with the bookshelves. The price increase to the floor standers in the Synergy line would be better spent to get into a set of Reference bookshelves. Of course this is all my opinion
Discussion Starter · #5 ·
hi colemad5 i am also concerned about music, do these all system do justice with music playback?
because i'm also fond of music as well as movies and games so guide me which system is good for all these. please do tell me should i go with floorstanders or bookshelfs speakers. what do u think about KEF's Q300 bookshelf, my friend have these Q300 for music listening and sounds good. should i go with klipsch or Kef???
Honestly it all depends on your listening habits and personal tastes. I have not actually heard the KEFs, but they have a great reputation for being musical speakers. From what I understand the two brands have completely different sound characteristics. The main thing is that a lot of people love Klipsch and a lot of people hate Klipsch. They really seem to be a polarizing company. KEF, on the other hand, has many fans and not a lot of detractors. Personally I love the sound characteristics of Klipsch. They tend to be bright and forward speakers that have great Dynamic range which make them great for HT and for a lot of modern music. If you are going to be mainly listening to music, especially jazz or classical music and not watch a lot of movies I would look at the KEFs. If you are looking for a great HT set that also works well for music I would look at the Klipsch speakers. The main thing is to make sure you like them. I ended up with a set of Klipsch Reference series speakers for my HT gear as you can see in my signature, but they may not work for you. There are so many great choices at any budget price point that you could go crazy analyzing every last detail of each set. Since the top of your budget seems to be around $1200-$1300 I would skip the floor standers as you will have to take a dip in overall quality to get them since they are so much more expensive than bookshelves. I don't want to cloud the issue but another great choice at this price point would be to check out Ascend Acoustics speakers. They have gotten near unanimous rave reviews here on the site and around the net for their performance in this price category and a 5.0 set with the CMT-340 SE mains, CMT-340 SE center, CMT-170 SEs run about $1200 plus shipping and a bit for stands. Add a Klipsch RW-12D from Newegg for $300 or a BIC F12 for around $200 on Amazon and that would be a pretty kick ass system. That definitely adds a bit to your budget but I think many people would tell you that the Ascends would sound better than any of the previously mentioned systems.
Discussion Starter · #7 ·
Thanks again your are of great help. what about Klipsch Quintet 5.0 + SW350 sub??? please share your opinion on these package. i'm from India and dealer told i will get these quintet + sw350 as whole 5.1 package for INR = 66000, US $1215 what do u think it is good 5.1 HTS or should i hv look for another???
thanks in advance.
Discussion Starter · #9 ·
Thanks i have checked it they are very cheap here in amazon man as compare to India. i think why klipsch products are costly here because due to import duties and taxes. now i'm planning to get myself a pair of Klipsch RF62ii floorstanders now what's your opinion on this one. please tell or i need sub with floorstanders ???
Originally Posted by swordfish86  /t/1465066/klipsch-home-theater-system/0_100#post_23124528
If you could afford those KEF Q300 bookshelf speakers, then this would be my recommendation. In the US, you can get comparable quality with the Ascend Acoustics SE series while saving a substantial amount of money, but I know nothing about their relative prices in India. If the KEFs would be more affordable for you, then in my opinion go for those.
Discussion Starter · #12 ·
Originally Posted by Robert Cook  /t/1465066/klipsch-home-theater-system#post_23126451
KEF Q300 cost INR = 33000/ US $606 a pair here in India.
I would definitely get the KEFs. The prices for the Klipsch speaker sets are way too much for the performance. Just try and find a nice sub to go with them.
Discussion Starter · #15 ·
Fellas i'm constraint on budget actually klipsch are way more expensive here in India than US. what do you think should i go for KEF bookshelf Q300 with which sub klipsch/kef/polk audio???
i have shortlisted some subs which comes in my budget are as follows ;-
1. Klipsch SW 350
2. Kef C4
3. Polk Audio DSW PRO 550
Originally Posted by swordfish86  /t/1465066/klipsch-home-theater-system#post_23130397
1. Klipsch SW 350
2. Kef C4
I would buy the Polk if i had to choose from that list, do you have access to other subs in that price range?
The polk just happens to be the best subwoofer that you have listed there. Are there other subwoofers in that price range that are better? Possibly, but its hard for us to help you with that because we don't know what prices for subwoofers are like in India, so we make suggestions based on given information and the Polk sub will play cleaner and deeper than the other two subs listed.
Originally Posted by swordfish86  /t/1465066/klipsch-home-theater-system#post_23125910
thanks in advance.
I would deff step up to atleast a bookshelf setup if in the same price range as the sattelites. I had the older Quintets with the 10" 450W sub and sounded great, but I did not realize what I was missing until I stepped up to a bigger package.
1 - 20 of 21 Posts
