1 - 16 of 16 Posts
Which of these speakers produce better quality sound for watching movies and sports on TV for a living room scenario.
1) Klipsch Reference RB51/RB61 speakers
2) Pioneer BS22 speakers
3) Bose Acoustimass 10 speakers
Would appreciate any comments
Out of those choices, the Klipsch would be the best by far. Bose shouldn't even be on the list, and the Pioneer are low-end budget speakers (although they are supposed to be decent for the price).
Originally Posted by gan222  /t/1497229/klipsch-reference-rb51-vs-pioneer-bs22-vs-bose-acoustimass-10#post_23892495
Gt Engineer
configuration is 5.1
price range is below $2000
So you need 5 speakers, a sub and an AVR? Room size? Main listening position distance?
And what does "Gt Engineer" have to do with this?
I think he was addressing me, "gtengineer". Ha!
I also believe Klipsch is a great choice for this budget. Of course with this much budget, quite a few other brands become available to you. Generally speaking, when a shopper has a budget like this to work with on speakers for home theater use, I recommend spending up to 1/2 of it on a good subwoofer since it is critical to the proper performance of a home theater system. I've been out of the home theater scene for a while so I don't know what the current go-to brand is for subwoofers. Back when I was in it, SVS and HSU were top brands. For all I know they still might be, but you should definitely ask around in the subwoofer forum.
^ oops. Missed that completely.
Originally Posted by gan222  /t/1497229/klipsch-reference-rb51-vs-pioneer-bs22-vs-bose-acoustimass-10#post_23892301
Why are you attracted to these 3 options?
Do you already have a receiver? If so, which make and model.
if the $2K budget is only for 5.1 you can do better than choice 2 and 3 for sure.
The klipsch without question
Discussion Starter · #11 ·
2k is the budget so if there are better choices please let me know
These options were recommended by a friend and I am not an expert so I posted for suggestions from experts in this forum
again does your budget include an avr. and for sub recommendations ,how big is your room and how far away do you sit from your tv.
Discussion Starter · #13 ·
yes the budget includes avr and sub
The room is 18 feet by 14 feet
Viewing distance from TV is about 16 feet
Look at the size of each speaker...and you should be able to eliminate one choise. For SQ of a speaker, size matter...
Originally Posted by gan222  /t/1497229/klipsch-reference-rb51-vs-pioneer-bs22-vs-bose-acoustimass-10#post_23894508
Look at the HSU Hybrid 5.1 packages - if budget gets tight, you can go 3.1 and get some smaller surrounds
http://www.hsuresearch.com/products/hybrid3pkg.html
http://www.hsuresearch.com/products/hybrid2pkg.html
AC4L has some refurbish Yamaha and Denon receivers
http://www.accessories4less.com/make-a-store/item/DENAVR2113CI/DENON-AVR-2113CI-7.1ch-Networking-Receiver-w/AirPlay-3D-Ready/1.html
http://www.accessories4less.com/index.php?page=search&search_query=denon+receivers&x=-796&y=-183
http://www.accessories4less.com/index.php?page=search&search_query=yamaha+receivers&x=-796&y=-183
1 - 16 of 16 Posts
