1 - 3 of 3 Posts
· Registered
Wire gauge is determined by the distance your speakers are going to be from the source, not by the type of speaker.
http://www.roger-russell.com/wire/wire.htm
That can help you determine if your wire is think enough for the runs you are making.
You may also want to look at Monoprice.com for speaker wire. 250ft of 14AWG inwall rated wire is ~$40.
1 - 3 of 3 Posts
