Status
Not open for further replies.
1 - 14 of 14 Posts
I know you can bypass kmixer with kermal streaming and ASIO in paticular programs. Aside from running foobar 2k, I run PowerDVD. Would the Kmixer effect the sound in any way? If so...is there a way of completely disabeling kmixer altogether so it wouldn't have an effect on the audio in my DVD's as well?
Are you doing SPDIF passthrough? If so, kmixer does NOTHING to your DVD's audio....
:cool:
Discussion Starter · #3 ·
I am sorry I couldn't replay to you earlier :) thats pretty cool so using optical doesn't use kmixer with dvd audio...how about any other audio, like CD audio?
DTS/DD(AC3) is packaged audio.... unpackaged audio goes through kmixer..... :(
The bottom line is, if its normal stereo and the software (whatever it may be) is configured to output via "Wave Out" or "Direct Sound", then it goes through kmixer.sys, and there's no easy way around this.
As Li On suggests, "reclock" may offer a possible bodged solution, but this is unproven at this time.
Chip
of course, there is then ASIO....
:cool:
Discussion Starter · #9 ·
Alright, I get the picture. Isn't there some way to fool around with kmixer in regedit or something? Instead of trying to bypass it all the time, why not just get rid of it once and for all?
MS applications will never use asio, it would like saying thank you to steinberg for showing them how to implement a good audio renderer ;)
1 - 14 of 14 Posts
Status
