Status
Not open for further replies.
1 - 5 of 5 Posts
I ran out of Knauf last night on my screen wall. :(
The screen will be mounted directly to the front wall as I do not have a microperf screen.
If I didn't have to put knauf on the screen wall, directly under the screen I would have enough.
Does anyone know if Knauf comes in anything less than 100 foot lengths?
I need about 16 feet, give or take a foot or two. :(
I never researched the OC 703. Does that have to be bought in large rolls as well?
Craig
Craig, you should be able to get Knauf in 2'x4' panels (1" thick).
Not sure about on-line but I just used my local Knauf dealer, Paragon Pacific.
http://www.spi-co.com/paragon.html
They might be able to point you towards someone closer to you.
Good luck!
Jason
Discussion Starter · #5 ·
Good luck!
Jason
Thanks Jason, I was just going to add to this thread that I just went ahead and bit the bullet and bought another 100 feet of Knauf from my dealer American Mechanical here in Michigan.
So I will be having a bunch left over. Perhaps for my next build.
Thanks again for your follow-up. :D
Craig
1 - 5 of 5 Posts
Status
