Use a test pattern with the graduated gray scale steps and adjust picture/contrast so you distinguish them all from each other. If its set too high the highest white levels will all look the same.
When there is some black after a bright scene, the "light" shadow of the previous scene remains on the screens (like the pixels are taking too much time to "turn off"). I am quite puzzled with this, as I have never had this behaviour on my previous set (KV27). I have been told that this was linked to the "set not broke in"... and that things should be better in a short while... |
even with contrast at full (very very bright), I am still having all grey squares defined and separated in the test pattern, and that blooming is just not happening |
