O.K. I think I'm glad I bought a Mits 55905, too, but I'd like to translate this issue into plain ol' terms of plug compatibility.
If I'm understanding correctly, the VGA connection to the Mits, which looks a lot like a computer interface, is the fire wire of which the article speaks. To make it work with the RCA DTC-100 - destined to be the DC-10 of HDTV receivers - I had to go to Radio Shack and get a plug with one end VGA compatible (like a computer monitor) plug and the other, the five RCA component connectors that feed out the HDTV signal. Again, if I'm understanding correctly, what the article is saying is that the DTC-100 won't be effective because of the absence of a digital output. Nor will any HDTV monitor that accepts only component inputs. But Mits owners, and those others that have a VGA type- input - if indeed it is that - will be o.k. My distant recollection when I was informing myself is that that connection is an IEEE whatever. That meant nothing whatever to me at the time.
What is puzzling is that I took on the `Net at The MITs HD500, the satellite receiver rear panel. That unit LACKS a `firewire' plug output. I am surprised the Mits people would not have included the same on their own machine if only to make the set-up more intuitively simple for the buyer.
All this is problematic for me personally, as I will almost certainly upgrade the unit in about eighteen months. But I find this issue easier to understand in terms of plug compatibility than engineering jargon The bottom line - if I've got this right - is that you'll need a vga type computer monitor interface on both receiver and monitor to receive the new signal. If all you've got is component outputs andin puts, you're screwed - really screwed, if the monitor is so limited, only semi-screwed if it's the STB, as these are considerably less expensive.
Please correct me if I'm wrong.
[This message has been edited by fdbjr (edited 07-26-2001).]
