Changing my mind about going sealed, AGAIN, with the Epik drivers i bought. The idea of an L-Shaped ported sub has got me interested.
http://dbdynamixaudio.com/l-slot-vent-bass-reflex-enclosure-calculator/
I put in information about my drivers and it came up with this (see attached)
L-SlotVentBassReflexEnclosureCalculator_DBDYNAMIXAU.pdf 501k .pdf file
i tried to model it in WinISD and was not sure if it matched up. I'm constrained by space and need to keep it to 24 x 18 x 20 for each box (need to build 2).
What do you think?
The T/S of the drivers is:
Znom 8 ohms
Re 5.7 ohms
Sd 805 cm^2
Pmax 400 W
Mms 200 g
Cms 250 uM/N
Vas 231 L
Fs 22.5 Hz
BL 23
Qms 4.1066
Qes 0.3061
Qts 0.2848
Le 3.15 mH
Spl 91.192 1W/1M
Xmax 13
Pete
What do you think?
Znom 8 ohms
Re 5.7 ohms
Sd 805 cm^2
Pmax 400 W
Mms 200 g
Cms 250 uM/N
Vas 231 L
Fs 22.5 Hz
BL 23
Qms 4.1066
Qes 0.3061
Qts 0.2848
Le 3.15 mH
Spl 91.192 1W/1M
Xmax 13
Pete
