Status
Not open for further replies.
1 - 2 of 2 Posts
My Panasonic 300U's fan seems to have developed a rattle upon startup. (At least I think it's the fan) The rattle stops after 15-20 seconds. The ph has around 300 hours on it. Has anyone else had the same problem or does anyone else have any info on a similar problem?
You sure it's the fan?
The bulb makes some shaking/crinkly noises on powering up (the manual even mentions it).
That said, I've gone through three 300Us myself.
First one had a group of bad pixels.
Second one was fine (convergense was even a bit better), but I noticed it's fan was noticably louder (or at a higher pitch) than the first one.
So the third one arrives and... its louder than the 2nd one. So, Ill keep #2 since it's my best choice now and I can't even be sure how much quieter the first one was (it was sent back already).
1 - 2 of 2 Posts
Status
