Status
Not open for further replies.
1 - 11 of 11 Posts
Discussion Starter #1
I'm trying to use my sony viro laptop at htpc.
Because it play great DVD movie picture on my sanyo front
projector. The only problem is the sound card.
Since it's a laptop, I can't use any pci sound card your
guys talking about here.
I found a usb sound card here: http://edirol.plands.com/shop/prod-g...temcode=362166
Can anyone tell me if this card is good for htpc?
aaron
Premium Member
not familiar with the unit, but it doesn't look like you could get surround sound out of it.
Alex
Premium Member
If you have a pcmcia slot free, then you may want to try a Margi DVD to Go card, which are available with a coax spdif out.
Ebay has a vendor who claims to be a Margi licensed reseller ([email protected]) selling them at $115 Buy Now. (he claims the retail is $299). His feedback is 577 +ve, 2 -ve, ie as good as they get.
I'm listing one of his auctions here http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1244865863 so you can see what I am talking about.
I'll leave it for you to decide whether this solution will work for you, and to do any price research from other vendors etc..
How to end the oil crisis:
Drill all the oil. Burn all the oil. No more oil crisis.
Discussion Starter #7
This is very interesting item.
I'm trying to find out if it compatible with my Viro
PCG-F540.
Could anyone tell me what is "zoomed video"?
Zoom video is, I believe, a feature of PC Card slots that you need to get them to do any high-speed video (like as a video input card or DVD decoder.) It is needed because the normal PCMCIA card spec has a very low bandwidth that could not normally support video.
But I think anything made within the last two years or so should have it.
Cal Z.
Mits 65903 (65" widescreen HDTV)+ RCA DTC-100
and
Gateway Destination 27" (Princeton Arcadia based)+HTPC (Pentium II 400, 256mb, 20gb+9gb HD, Radeon LE, cybertainment tv tuner, asus dvd-rom, hercules game theater xp, Kenwood VR409 DTS receiver)
[email protected]
Discussion Starter #9
my viro PCG-F540 was made last year and I bought it this
January. guess it has zoomed video.
I think I'm going to give it a try.
I send the seller a email regarding my viro compatibility
and also if I can get video from the laptop VGA when playing
DVD movie. But I haven't got any response from him yet.
After carefully reading the auction page http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1244865863
I found this paragraph
"You see, otherwise, without the dongle, you can't play your DVD's anywhere else but on your laptop. With the Dongle, however, you can play it on any TV via RCA jacks (red, white, and yellow) or S-Video"
I guess this mean I CAN get video from my laptop VGA output.
Correct me if I'm wrong.
Discussion Starter #10
I just got the response from edirol
"The UA-30 is not designed to work with surround sound applications"
That will take care my question.
1 - 11 of 11 Posts
Status
