1 - 2 of 2 Posts
I have a 72 inch? Mitsubishi. I measured on a diagonal only the screen, so I probably don't have the correct number.
It began flickering and being discolored a couple months ago. It's strange, because it will sometimes not flicker at all, but still without the correct colors, sometimes the whole screen flickers, and now it's just half of the screen. I am talking, exactly half of the screen, and garbled to the max. It looks like it is colored with black and white splotch colored glitches, if that makes sense.
Is this a problem with the lamp, color wheel or something else? Is it something I can fix myself? (I fix electronics a lot). Or am I better off having a pro fix it or getting a new tv? It is huge and heavy… ugg.
Need model number off the back of the Tv.
If you bring up the Tv menu with the Mitsubishi remote, is the menu ok?
Take pictures of the whole screen. Good quality, showing the entire screen, with various content/channels, and a few with the Tv menu on screen. Post the pictures here.
1 - 2 of 2 Posts
