Status
Not open for further replies.
1 - 6 of 6 Posts
· Registered
Can anyone recommend a laser player AC-3 demodulator so I can connect to my MC-1? Lexicon does not sell their LLD1 demodulator any more. I was told to check with Kenwood for their DEM-9991D demodulator. So far no luck. Can anyone recommend a internet dealer who sells AC-3 demodulators that will work with a MC-1?
· Registered
One of the best out there is the Meridian 519 Laser Disc demodulator unit. You won't find it on the net, only authorized dealerships can sell Meridian. I would recommend this one first, but you may find another company brand that sells on-line.
Jeff
· Registered
As I posted recently, Nakamichi is clearing out their stock of RF Demodulators. The model is called the DE-1, was originally $450, and should be available for under $200. I don't know how it would compare with the Meridian unit.
-Aerlith
· Registered
i had a lot of synch problems with the LDD-1. traded it in for the Meridian 519 and it's been rock solid...
dave
Widescreen DVD - Because a superior format requires superior formatting.
· Registered
Discussion Starter · #6 ·
Thanks for everyone's recommendations and suggestions. I decided to go with the Meridian 519 and Deniz Mutlu's offer.
1 - 6 of 6 Posts
Status
