Latest info./opinions on Pana. E-95 (not E-85)
386 Views 2 Replies 3 Participants Last post by  7481387
I was really curious about the Pana. E-95 (vs. the E-85).
There are alot of threads on the E-85 but very few re: the E-95.
I see alot of mention of problems with the E-85. Do these same issues apply to the E-95? Is it more reliable? Other than the card slots and larger hard drive, are there any other differences in use and performance?
I am considering both and I would appreciate any and all advice!
MANY THANKS!
Status
Not open for further replies.
1 - 3 of 3 Posts
I have had the 95 for about 4 weeks and I have not had any problems so far. However, I have not burned any discs with it. I have only used the harddrive to record shows from my Samsung HDTV turner. Of course the recordings look great in both XP and SP modes. The TV guide works ok but only shows like an hour ahead per page, not far enough ahead to me. I have not been able to get the card reader to work with my pictures. Somone posted that it only works with jpegs from certain cameras. I have used the firewire input to record from my DV camcorder and works ok.
Originally posted by slprp1
I was really curious about the Pana. E-95 (vs. the E-85)....Other than the card slots and larger hard drive, are there any other differences in use and performance? :)
As DvdJags mentioned above, the E-95 has a DV ("firewire") input. The E-85 doesn't.
1 - 3 of 3 Posts
Status
