Status
Not open for further replies.
1 - 1 of 1 Posts
Hi there,
I'm building a 12.5' x 20' x 7.5' "room within a room" home theater in my basement. What order of materials should I use for the walls to achieve highest STC? I'll be using R13 batts in the walls & ceiling and a generous amount of acoustical chalk throughout. My primary goal is to keep the bass contained.
Key:
Metal Studs (s)
homassote (h) - also will be used as a subfloor between concrete floor and carpet padding
30# roofing felt (r) - already have enough purchased for two layers
5/8" drywall (d)
Option One:
S R R H D
Option Two
S H R R D
Option Three
S R H R D
Option Four...????
Adding a second layer of drywall or homasote is an option, but hopefully not necessary.
- T
BTW - I'll be using 20' long metal "struts" as a second set of ceiling joists, so the interior room will be touching nothing except the poured concrete floor.
1 - 1 of 1 Posts
Status
