1 - 6 of 6 Posts
Can i get 1920x1080 connected to a computer ?
Discussion Starter · #3 ·
Well, you didn't specify how you planned to connect the PC to the set. If you go with the set's pc connection, you already have the answer.
If you plan to use an HDMI connection, and your computer's video card supports the desired resolution, the set will display it.
Discussion Starter · #5 ·
oh thanks got me consufed for a sec.... it will be HDMI....
It'll work then, as long as it's HDMI
1 - 6 of 6 Posts
