Status
Not open for further replies.
1 - 6 of 6 Posts
I was just wondering if it was able to use a LCD comptuer monitor as a tv display with only hooking up say an DVD player??? will this work?
I did some searching on the web, but couldnt find anything that said yes.. anyone have any links for this type of stuff???
Can it be done?
Most computer monitors have RGB connections. If you have a device that outputs RGB, you should be able to connect it to your computer monitor.
Discussion Starter · #3 ·
i have seen some with an svideo so i thought it would work.. just wondering if anyone has done this or seen any information on it
would be a cheap alternative for the bedroom 300 for a monitor compared to 1200 for a lcd tv
I have a samsung MP150 that is an LCD monitor with a tuner, svid, and composite input (as well as audio). TV pic is okay (kinda grainy), but acceptable for the kitchen, and we use it as a monitor as well, so it's a great little machine.
Other options are to buy the monitor of your choice, and then get a scaler of some sort (Viewsonic makes a couple that are reasonably priced...)
http://www.viewsonic.com/products/vi...x_vb50hrtv.htm
Cheers,
Rich
tivo1
I played a couple of DVDs (as a test) on my highly-rated Samsung 191T monitor from a DVD-RW drive (in a PC) via DVI connection.
I was not very happy with the results. I think, a dual-use monitor, like Boykster mentioned, is a better idea.
the "newer" samsung 171/151MP monitors supposedly have better NTSC performance as well (over the 150/170 series like mine). Also, I believe they have HDTV comp inputs (don't quote me).
Cheers,
Rich
1 - 6 of 6 Posts
Status
