InFocus Proxima
Model DP2000x
S/N AGFN31100162
Apparently the projector started "bleeding" from top to bottom. After replacing the bulb, the projection has a large green blob on the bottom and the rest seems to be tinted pink. Not sure if the pink is supposed to be there or not. The green blob looks like it has water or some liquid sprayed in the bottom right corner that you can focus and unfocus, so the lens is clean. We cleaned the lens and the bulb, no fix.
Would this problem be inside the projector or on the bulb? An easy fix?
Thanks in advance. I'll check in often if I need to answer questions.
Model DP2000x
S/N AGFN31100162
