1 - 7 of 7 Posts
Hey AVS,
Ok heres my plan. I am putting in a new office in my home since my new job allows me to work remotely. I have a main computer monitor that I will use so the LCD TV will be a secondary display I would like to be a combo display that I will use for TV and as a computer display. I was thinking of Dells new 23" LCD TV but knew yall would know best.
I will be wanting one sub 500.00 since I will be buying two, one for the office and one for the bathroom. So something less then 24" would be fine as well. The aspect ratio is important to me as well and would like it to be wide screen format.
Thanks AVS
Chris
Go to Wal-Mart and buy Emerson or Sears/SamsClub Sylvania have 20" LCD
Specs
TV Features
20" TFT VGA LCD Screen
Pixel Resolution: 640 x 480 x 3 (RGB)
ED Display (HD Signal Applicable)
Response Time: 16 ms
Natural Color Matrix
Natural Scene Clear Circuit
3-Line Digital Comb Filter
Contrast Ratio: 500:1
Brightness: 420 cd/m2
View Angle: Vertical: 155 deg
Horizontal: 170 deg
181-Channel PLL Frequency
Synthesized Tuning,
MTS-Stereo, SAP Sound System
Automatic Channel Preset
CCD (Closed Caption Decoder)
V-Chip Function
Remote Control for all Functions
Trilingual OSD
( English/Spanish/French)
Picture Controls: Contrast, Brightness,
Color, Tint and Game
Sleep Timer
Resume Function
Component Video Input 1 Set
S-Video Input 1 Set
Composite Video Input 1 Set
Audio Input 2 Sets
Headphone Jack
Dual Speakers
Tilt Stand Base
Product Dimensions (WxHxD):
24 1/2 x 19 1/8 x 10 5/8, 20 1/2 lbs.
Carton Dimensions (WxHxD):
27 5/8 x 23 11/16 x 12 13/16,
23 5/16 lbs.
UL Listed, FCC / DHHS Certified
Owner's Manual In English and Spanish
476 Sets/High Cube Container
357 Sets/40ft. Container
UPC Code: 053818680135
Or
Goto Target and Trutech Shown below
15.0" Screen Flat-Panel TV with LCD Technology
High Definition with Built-In HDTV/ATSC Tuner
Built-In Stand
4:3 Standard Aspect Ratio
1024 x 768 Pixel Resolution
Contrast Ratio: 400:1
V-Chip
Closed-captioning
Stereo Sound
6W Total Output (3W x 2)
Remote Control
Stereo Speakers
Operational Features: On-Screen Adjustment Menu
Operational Modes: 250 CD/M2 Brightness
Compatible with 1080i/720p/480i/480p Resolution Specs/Video Modes Formats
Accessories Included: Remote Control
14-1/5Hx3-2/3Wx15-3/5L
Wall mounts
I own the Trutech you see above and it does a good job displaying HD content at 1080i using component video (green, red, blue) I also tried progress scan at 480p does a good job also. 720p on those HD stations too..
If you want 16:9 there are sets from VIZIO like 20" LCD Widescreen.. Pricy and image isn't as sharp as above. You'll find that at Costco.
I'll put my reccomendation in for the TruTech 19" at Target
19.0 " Screen LCD Flat Panel Television with LCD Technology for Crisp Images and Thin Design, LCD Technology
Includes LCD Television, Speakers, Stand, Remote Control, Flat-Panel LCD TV for Great Images with No Burn-In, Desk Stand, Color TV
HD Display When Connected to an Optional HD Source
NTSC/ATSC Built-In
Video Features: JPEG Viewer to See Your Favorite Photos on the TV, Zoom Feature, On-Screen Adjustment Menu, TFT Liquid Crystal Display (LCD)
Audio Features: MTS, Broadcast Stereo
My girlfriend had this TV for the built-in DVD player. I put it in my office for some background noise, plugged it into my wall cable, which I only have basic. The QAM tuner on my plasma picks up all kinds of digital stations, but I didn't expect this little cheapo TV to do the same. Not only did it pick up all the HD stations and digital stations that my plasma picked up, it ALSO picked up stations my Plasma did NOT with the automatic scan. The stations I didn't know I had were Fox News, Turner Classic Movies, and the History Channel, 3 of my favorite stations. (depends on your local cable company I'm guessing). I love this little TV for this reason alone. The 1080i is very nice as well.
My girlfriend got it on Black Friday for $199 at target. Currently is over $300, but I would pay it for this little thing if I didn't already have it.
I own the 15.0" Trutech LCD TV from Target shown above and I 'll put my recommendation for it. It does a great job displaying HD programs. Even the low definition programs look great with it. I find that the preset picture modes are very good. I played with the color temperature and the warm temperature looks best to me. Also I find that the HDMI connection is slightly better than the component connection. I bought it for $240. would recommend the TV to anyone.
1 - 7 of 7 Posts
