LED Dimmer for Star Ceiling
397 Views 3 Replies 3 Participants Last post by  Todd_zilla
Lisalynn had talked about using LED's for a light source for a fiber/star ceiling.
Lisalynn or anyone else.... What type power requirements are needed. I want to hook one up to a Grafik Eye as a Zone.
So I guess I'm looking for a 120v transformer to be able to dim it down as/if needed??
Any ideas?
I really like the aspect of low heat and length of life on the bulb(s). The color does more realistically match the night sky too..
Thanks in advance!
Status
Not open for further replies.
1 - 4 of 4 Posts
We use a 5v. DC power supply, and hook up our setting on the Graffik Eye to be aa on/off setting.
To dim LEDs you use a trim pot which is varies the resistance, not the voltage. I have not heard of an interface that can be used with the Graffik eye to dim LEDs, but I'm sure someone is working on it.
Do I have a market for a twinkling LED starfield illuminator?
YES.....
Can you PM (Private Message) me please, some contact info so I can talk to you.
I'm very interested in creating this starfield effect as well... please send me some info.
1 - 4 of 4 Posts
Status
